How do you prep an engine that's been idle for months?
I recently purchased a 2005 Dyna SuperGlide with 52,000 miles on it. It was in bad shape, and it had been sitting on an auction lot for months waiting to be sold. I drained all the fluids,put in Motul 20w50 Synthetic for the engine and changed the filter (also changed transmission fluid). 480 miles later, I take a trip outside the city when the engine begins to make this knocking noise in one of the cylinders. I stopped and checked the oil, there was very little left and it was pitch black already. Needless to say, I stopped right then and there and trailered it home. Should I have cleaned the engine more thoroughly with motor flush or something like that before replacing the fluids for the first time? How do you make sure you've cleaned it well from the inside before putting a bike back on the road where it belongs?
A little more info:
1. The bike has a cone shaped filter, facing downward. Don't know if that has anything to do with it.
2. Bike starts and runs. I just didn't want to keep going with that new noise.
3. The noise is a clank, like metal hitting metal, though I'm not entirely sure. The noise is loudest when the bike is idling, and decreases when you open the throttle.
4. If an overhaul is required, what should I buy and where should I buy it?
Thank you for your time!
A little more info:
Sounds like you MAY have caused some damage, oil pressure is it's lowest at idle, which explains more noise then.
If you could see oil on the dipstick usually you are ok, but the noise you describe makes me think that may not be true in this case.
Was it burning oil or leaking? Oil had to go somewhere if you filled it.
Change the oils, check the drain plugs for metal shavings. Put in fresh oil and see if you still have the noise.
I would also do as 07 described above and check the cam tensioners.
You bought a bum bike w/ problems from a typically disreputable source. Take it to a pro who can troubleshoot it properly. And order the service and parts manuals.
Well, I live abroad so I had to look for the most "cost-effective" options available. I paid more in shipping, handling, and customs than what I paid for the bike itself.
BTW, thank you for your input (and everybody else's), there is so much I need to learn. I'm getting the service manuals in a couple of weeks, time to get down and dirty with this bike! There is no "take it to a pro" option in these parts, as they don't service imported bikes.
I'll start by changing the oil (and filter) for the second time to see how this affects the noise. I'm pretty sure riding outside the city and using 4th and 5th gears for long distances really loosened up whatever dirt and other contaminants the engine might have held inside from being inactive for such a long time.
Received 4,857 Likes
My first question is "how familar are you with this Superglide?" Do you know what drain plugs drain what? Do you know how much oil to put in after you drain the old out? How much of a pain will it be to put the stock oil filter mount back together? Did you know in advance the locals don't work on "imports"? I truly hope you are a somewhat skilled mechanic because in all seriousness it looks like you will be your indy. If I ragged on you too much then I apologize, like previously stated sounds like you bought someone elses problem.
And yes, I knew the only local dealership doesn't work with imported Harleys, but I'm not in the position to buy new at this moment in time. You gotta do what you can with what you have! The good thing is I have the help of other biker friends whose experience vastly surpasses mine, so I'm not really that worried about this issue, troublesome as it may be.
I just hope the wrenching I have planned for the weekend solves the issue.
