Over tightened clutch lock nut.. consequenses??
When tightening down the lock nut on the clutch adjustment screw I used a ft-lbs torque wrench instead of a in-lbs (stupid error)…. didn’t realize until I had turned the nut several times (probably several times more than it would have been). I loosened everything back up and finished the adjustment but had no bite in the clutch lever afterwards… started from scratch again and it was OK.... Didn’t really reduce the clunking during shifting but I think neutral is easier to get.
Should I be worried about any consequences of over tightening the lock nut?
Thanks.. i think I may have done that.. will replace it for peace of mind... phew!! I was worried I could have knackered the inards of the clutch... was fretting there for a bit. Thanks again.
Sure thing. The cool part it a standard fine nut will be taller and not short like a jam nut so it will be easer to grab with a wrench.
