engine ticking noise when warm
I had ticking when my oil line blew off.
Good thing for me I had Amsoil and there was no damage whatsoever.
I refilled with Amsoil, drove it home and changed the oil again.
Absolutely no metal on the magnetic plug!
Amsoil is great stuff.
Ended up modifing the oil cooler to fit AN6 flare fittings and stainless braided hoses.
geeze. im glad to hear this because i just bought a fat bob. new to the big air cooled twins. same thing. bike is mint 2008. 9k on it. no modifications. all records say oils changed at 1k 5k and 9k. pulls hard and sounds great except when it gets warmed up good and hot. hear a slight ticking noise when cruising. guess im just used to jap racing 4 stokes
Mine did the same thing dealer said its normal. Recentaly changed my motor oil (20w50) and transmission to Amsoil what a differance! The motor lost its ticking and has almost 700 miles since oil change. Just changing the oil has made a big differance.
Does it seem to get louder as you roll on the throttle and quieter when you idle along or just maintain speed?
I'm discovering the "normal" tick can be quieted with additives or different oil ... But NOT synthetic which seem to allow more sound to be heard.
I just added a LUCAS oil additive and was quickly pleased to not hear the high pitch lifter ticking noise. It's actually the design of the motor with the angle the pushrods strike the rocker, and it being open air cooled motor allows this sound to be heard outside of the motor.
Mine doesn't tick all the time..just when it's running!
Built almost the same motor for my brother and it sounds great...both 2006s.
I hate it, but after tearing into it and replacing things that didn't need replacing several times, I said the hell with it...I ride it like I stole it and if it blows up I will build it again.
