2005 FXDX 13 spoke mag wheels on an 2007 FXDB
Old 08-11-2012, 12:02 PM
DoubleZ's Avatar
DoubleZ
DoubleZ is offline
Anybody know the part numbers for the 05 rims with the 1" axel?
  #32
Old 08-11-2012, 12:07 PM
Good_Apollo's Avatar
Good_Apollo
Good_Apollo is offline
The 3/4" will work as well, just gotta swap bearings and sleeves.
Aza23 (01-16-2017)
  #33
Good_Apollo
Just a quick note and something to think about. The HD slotted six spoke wheels would give a similar look if powdered black and also support dual discs. A lot less work since they bolt right up
Aza23 (01-16-2017)
  #34
Old 08-11-2012, 12:25 PM
DoubleZ's Avatar
DoubleZ
DoubleZ is offline
cool. so then any oem 13 spoke mag will work? are there any differences between the sportster and dyna mags? different years? i want to try and pick some up at a swap meet so i want to make sure i dont get something that wont fit
  #35
Old 08-11-2012, 07:57 PM
Good_Apollo
Just make sure they are 2000 or newer, need to be setup for sealed bearings, the older ones had the old school bearings that had to be packed with grease every so often
  #36
Old 08-15-2012, 12:07 PM
07bobber's Avatar
07bobber
07bobber is offline
okay guys im back in the game with some 13 spoke wheels again...this time i got the two toned black and polished wheels...
next will be getting the wheel bearing kits and some front spacers then some tires..
  #37
Old 08-15-2012, 03:50 PM
McGinnes_john's Avatar
McGinnes_john
McGinnes_john is offline
Those 2 tone wheels look awesome! Good luck with the swap!
  #38
Old 08-15-2012, 05:24 PM
07bobber's Avatar
07bobber
07bobber is offline
Originally Posted by mcginnes_john
those 2 tone wheels look awesome! Good luck with the swap!
thanks man! Youve already helped me out a lot...
  #39
Old 09-01-2012, 03:42 PM
McGinnes_john
Bit of an update on the front wheel spacers. They work significantly better machined to 1.1" (On the nut side) and 1.22". With the old measurements the spacers weren't quite as tight as they should be with my fork brace installed. The new set up works perfectly.
  #40
Old 09-04-2012, 01:39 PM
07bobber's Avatar
07bobber
07bobber is offline
....09/04/12 updated the first post....
Quick Reply: 2005 FXDX 13 spoke mag wheels on an 2007 FXDB
