Injector swap from 8 degree to 25 degree on my 06 wg
Old 05-21-2012 | 06:22 PM
macnab_sf's Avatar
macnab_sf
Originally Posted by dynarule
Did you have to update the ECM?
I did on mine (tmax) since they have two different maps. I dont know about oem.
Old 05-21-2012 | 08:14 PM
SURFOR Chop's Avatar
SURFOR Chop
They retail for over $90 ea (discounted price I just saw was $72.80 ea) ... so ~$150 - $200 for the fix ...?
R/
'Chop
Old 05-22-2012 | 01:26 AM
macnab_sf's Avatar
macnab_sf
Ebay - way cheaper.
Edit: got mine from amproparts
Old 05-22-2012 | 08:56 PM
misfitJason's Avatar
misfitJason
I too have the 25mm it was a warranty issue from when I bought my 06 new in 07 as a leftover and they fixed the comp issues and primary problems as well as changing the faulty shifting problems with the Andrews components. What makes me curious is I wonder if the fuel efi tuners I.e. fuelpak need to be made aware of this swap for the proper map?
Old 05-22-2012 | 09:46 PM
nkauf21's Avatar
nkauf21
I believe you need a new map when switching from the 8 to 25 degree injectors. I have the 8 degree injectors still. I had a PCIII installed and my bike dyno tuned before I found out about switching to the 25 degree injectors. My bike runs solid so until I have a reason to get it tuned again I won't be switching them out.
Old 05-23-2012 | 10:38 AM
JRK5892's Avatar
JRK5892
they did not cover the warntee if you have a tuner in the bike from HD... just so you know.. they said that the map fixed the issue.. only stock setups... i fought it all the way to corprate at HD and still got the no go... i picked both of my injectors off a 2009 street glide for $50 for the set when he upgraded his motor build
06lowrider
04-21-2009 09:21 PM
wydopn231
04-19-2008 10:54 PM
NCCopBikeRider
10-28-2007 06:29 PM
tooch69
11-28-2006 10:10 PM
denied
07-10-2006 09:32 PM
Quick Reply: Injector swap from 8 degree to 25 degree on my 06 wg
