HD LED lamp in Cobra II bucket?
Old 05-04-2012, 03:49 AM
pheur's Avatar
pheur
pheur is offline
Default HD LED lamp in Cobra II bucket? (updated with pics, it works!)
Hi,
I believe I have read here about fitting the HD LED lamp (part number: 67700043A) in the classic "Cobra II" headlight bucket?
http://www.accessoriesunlimitedsouth.com/cobra2.htm
Can someone share if they have more information about this? I have the HD LED lamp and I really want a "Cobra II".
Old 05-04-2012, 06:42 AM
ll Legion ll's Avatar
ll Legion ll
ll Legion ll is offline
I seem to remember that it could be done, but I haven't tried with minne yet.
Old 05-06-2012, 05:28 PM
Alain's Avatar
Alain
Alain is offline
anyone know how much that HD LED lamp is?
Old 05-06-2012, 05:49 PM
DavTN's Avatar
DavTN
DavTN is offline
I put it in mine, tight fit but works. Drilled out the hole for the wires a little, then spliced the wires (couldn't get the pins out of the stock plug) used the stock rubber boot with some silicone. Huge improvement.....the light is expensive, but the stock light on the Rocker sux IMHO. Now I can actually see where I'm going. Oh, Put some anti-seize on the trim ring so you can get it back off when needed.
Old 05-06-2012, 07:37 PM
DavTN's Avatar
DavTN
DavTN is offline
Old 05-06-2012, 08:37 PM
Alain's Avatar
Alain
Alain is offline
do you remember how much you paid for the LED?
Old 05-06-2012, 08:54 PM
DavTN's Avatar
DavTN
DavTN is offline
$319.96 from Surdyke. PN 73273-11A
Old 05-07-2012, 06:17 AM
Alain's Avatar
Alain
Alain is offline
thanks
Old 05-07-2012, 07:51 PM
Baeseman1's Avatar
Baeseman1
Baeseman1 is offline
When I installed the Cobra II I re-used the stock HD glass. If the LED is made as a direct swap, no reason it wouldn't fit.
Old 06-18-2012, 06:52 AM
pheur's Avatar
pheur
pheur is offline
Hi,
I have now swapped my headlamp bucket to a Cobra II and fitted the H-D LED lamp in it!
Thanks to help from among others Baeseman1 I also did not cut and splice but dissasembled the connector inside the old housing and fished out the wires. This was very good since I can always go back if I want to.
I thought I had it all figured out but of course you always have to overcome one obstacle. In this case it was that the Cobra II did not have a big enough hole for the wires with the spade connectors. I had to drill a bigger hole, no biggie at all but it had to be that or splice.
Attached is a few pictures of before and after and one of the connector before dissasemble.
Attached Thumbnails HD LED lamp in Cobra II bucket?-2012-06-16-13.57.46.jpg   HD LED lamp in Cobra II bucket?-2012-06-16-14.50.17.jpg   HD LED lamp in Cobra II bucket?-2012-06-16-19.33.04.jpg
Quick Reply: HD LED lamp in Cobra II bucket?
