Will Streetbob wheel fit on a Wideglide?
Ok there is no simple answer without more information.
If the Street Bob wheel has the original mid glide aluminum hub, the wheel will not fit the Wide Glide without custom size wheel spacers.
If the Street Bob was converted to wide glide trees and the wheel has the wide glide hub, it will fit the WG with no problem using the factory wheel spacers from the WG.
Most likely the wheel is a standard Street Bob mid glide hub and would require custom spacers to be installed on the WG.......
You can have the wheel laced to your WG hub, which would solve your problem......
The reason Doom went through the whole explanation of hub size and why your research turned up nothing is because no Street Bob ever came from the factory with a 21" wheel. Somebody either converted the Street Bob front end to a Wide Glide or relaced a 21" rim the the Street Bob's Mid Glide hub.
