Nasty oil spillage...too much oil? Where would it overflow from?
I changed the oil in my new '96 DLR on Saturday. I changed the filter and put two quarts of Mobil 1 in there, idled it for about 10 minutes, and filled til it said FULL HOT. Took exactly three quarts. Due to weather, I wasn't able to ride it that day. I did notice the semi stripped drain plug leaking, so I dumped the oil and redid the drain plug, then put the "new" oil right back in there. Same amount. Today was the first day I was able to ride, and there's oil all over the place around the dipstick, tranny, and dripping in multiple locations. When I check the level, it reads overfull at temp. My searches indicate that 3 quarts is capacity with filter change, and if anything, I Should have less in there due to the leaking, so what gives?
I'm ready to dump the oil again and start over so I Can ride without making a mess and looking douchy.
My 08 street bob when it was stock would spit oil out if I put any more than 2 quarts in with a filter change. Now with an oil cooler and a 106 2.5 quarts is all that will go in without oil dripping out of the breather.
I run my bike so that the oil is about an inch up the dipstick when hot. Any more than that and it spits.
Abouthow much oil came out when you drained it? (The second time) Was it around 3 its...or around 1qt? Im not questioning your skills, but I just got home from my buddy's place for the same head scratcher...come to find out in his haste, he pulled the trans plug...and dumped an extra qt back into his crankcase...
If my memory serves me correctly, I believe the capacity is 3 quarts "dry" but for an oil "change" I believe it's 2.5 quarts. Somebody please correct me if I'm wrong...
You never add three full quarts it's just too much oil. (cept on first fill which comes from the dealer) .should only need to add 2.5 as others said. Now you took out the oil and added three a second time without emptying the filter....to much! since you already have a mess just pull the plug and take out at least a quart and go from there. When oil spews out of the dipstick what does the dipstic read? achh noobs LOL <--- just joking we all make mistakes its normal!And the most embarassing ones are where we tend to learn the most from!!!
