Nasty oil spillage...too much oil? Where would it overflow from?
Remember, when I drained the oil the second time, that oil went right back in...didn't add any additional.
Something else came to mind as well: After changing the oil and running it at idle, the oil looked like ***. I assumed it was from a dirty engine (previous owner didn't remember when the oil was changed last) and planned on doing a series of quicker changes to flush the system out (no solutions, just new oil/filter). Oil remaining in the lines and nooks and crannies would dirty up the new oil quickly and definitely account for an overfill.
And yes, I read the manual and took the 3 quart capacity as bond. Won't do THAT again!!
I'll drain the oil and refill with two quarts and go from there. I appreciate the suggestions!
And the problem is that the previous owner did not use a torque wrench, and now the plug is stripped...I need to fix it.
Spot on. I had an old manual oil pump in my tool chest, sucked out some of the oil and took it for a nice long ride. No spillage. Drain plug is still doing an occasional drip, so it will still need to be properly addressed, but now I can park in a driveway without making a God awful mess!
Received 4,720 Likes
And is how you learn about servicing your own machine. One thing I learned about my trans oil, I put in a measured 22ozs., if you go to 24 ozs.when it gets hot it could vent then you have another mess. It might be a bit **** but I pre-measure my fluids prior to pouring them in the holes, then top off only if and when neccesary.
