Springer front end on a dyna super glide ????
The Dyna, and Sportster neck for that matter, are different from the Softails. As a result very few Springers fit. The Paughco is a direct bolt on but others such as the factory Springers and the DNA's are designed for Softail and pre-Evo necks. They can be modified to fit, but they take quite a bit of work. I recommend spending the extra cash and getting the bolt-on Paughco. That is what I am currently running now as surfor chop mentioned.
Chromedome mentioned a American Suspension on the way. I put one on back in 2008 and have racked a good amount of miles on it now. Very well designed springer. Is a wide glide tree design so interference with the tank will limit turn radius with a 0 offset tree which I needed to keep trail in check. I moved the tank back some and adjust fork stops accordingly. It doesn't turn in the garage as sharp as it use to but on the road it does it all in spades. Attached some pics, is not a superglide is a wideglide which has more rake in the neck. Not sure if mounted on a superglide if the trail would be in check. No matter the springer I would run a calculation on the trail. Cheers on the future project.
Dave England (02-25-2020)
I've been shopping for a springer for my 06 SG. I looked at the American Suspension website, but there is almost ZERO info about them. I like being original, but when a Google search brings up nothing but the manufacturer's website, something is wrong. Personally, I'm going with a Twisted Choppers wide wishbone soon as I get my rear end dropped and can get a good measurement of what I need
Front end
Attachment 533945
Attachment 533946
Attachment 533945
Attachment 533946
Sparkplug666
03-10-2015 02:20 AM
