Fatboy fender on Fatbob
I have not seen it done ... but, I believe it is possible ... there is an 'L'-shaped adapter for the fender mounts that can be used with the Fat Bob lower fork slider to change the orientation of the fender bolt pattern from vertical to horizontal ... this would allow the use of a Fat Boy or Street Stalker fender ...
AFMM3 fabricated a set of his own design, but I believe there is an adapter setup made by Klock Werks ... AFMM3 is using a Heritage fender on his '08 Fat Bob front fork ...
R/
'Chop
R/
'Chop
Here's a link to Klock Werks web-site. They have a mounting block you can use to mount any Fatboy front fender.
http://www.kustombaggers.com/Klock-W...atalogId=-1812
I have bought them for an upcoming project.
These are the ones I made to fit my Street Bob forks. They should have an 87 degree angle for proper bender orientation. The Klockwerks adapters are for Fat Bob sliders only and were designed specifically for Fat Boy fenders although a Heritage Classic fender will also fit. Forum member Lone Watie purchased these (after waiting several months on back order) and is using a Heritage fender with excellant results.
