battery tender hard wiring route?
hi, i'm stuggling to find a way of routing the wiring to the battery.
i have a 2011 fxdc, the tender is a waterproof 800 battery tender.
the + wire has a large fuse link, 4"from the ring connector.
does anyone have a way of connecting up? and where to exit the connector plug.
pictures would be good, if possible.
thank's in advance.
grumpy.
thank's in advance.
grumpy.
ok. I was able to thread the wire-cord beside my ignition switch/battery box and into the battery compartment so that 'just enough' of the connector-plug wire hangs out for BT connection. The battery-connection end w/fuse tucked in well enough. If I need to deal with the fuse I have to remove my seat....no big deal.
remove the battery, at the front of the case there is a slot where the positive cable runs that goes out the back of the case - run your leads out that hole and over to the left side of the bike where you can tuck it away until needed. Run the leads over the top of the battery and secure the fuse holder with the rubber battery band, you don't need to cut anything.
benningtonr
2014-2023 Touring Models
11
03-04-2017 07:10 PM
