Calipers.."Brembo or PM"
Old 04-20-2012 | 09:41 AM
Griff012FLHX's Avatar
Griff012FLHX
Default Calipers.."Brembo or PM"
Ok guys and Gals..
If you was to switch out your Stock Calipers, What would be your choice....
Brembo.
Performance Machine.
I knida like that Brembo with the 12.6" rotor combo, thats supposed to be direct bolt on....
Motorcycle super store sells it....
Old 04-20-2012 | 10:23 AM
Brewtality's Avatar
Brewtality
I went with JayBrake
Old 04-20-2012 | 10:26 AM
Hogpro's Avatar
Hogpro
Former Sponsor
Ride a bike with the Brembo's. They work great. The rotors for the brembo's (at least on the baggers) are 11.8". You can also get a 13" (300 mm )rotor and a bracket from RC components that will raise the caliper to accomodate the 13" rotor. PM also makes a caliper for 13" rotor and 13" full floating rotors.
It is a tough choice between the two. It all comes down to how much you want to spend.
Old 04-20-2012 | 11:33 AM
sonnydaze's Avatar
sonnydaze
brembo they are a brake company , not a wheel company that makes brake stuff . having said that i have a bike with pm brakes and they are good but not brembo good
Old 04-20-2012 | 01:25 PM
07bobber's Avatar
07bobber
id go brembo.....
Old 04-20-2012 | 01:37 PM
ynots's Avatar
ynots
+1 bremco has my vote
Old 04-20-2012 | 02:34 PM
Willy723's Avatar
Willy723
If your main concern is braking performance then the answer is Brembo, if you are replacing for aesthetics as well and not concerned about best possible braking then my answer would be this: If you have PM wheels, go with PM Calipers, if you don't have PM wheels go for the brembos.
Old 04-20-2012 | 05:19 PM
PhotoRider's Avatar
PhotoRider
Does Brembo make 6 piston versions for a dyna (2000-2005). I can't find any info on them?
Old 04-21-2012 | 01:28 AM
imboden's Avatar
imboden
I put a 4 piston PM on the front of my springer.... it has amazing stopping power. but I also wanted the black contrast cut to go with my contrast cut wheels....
Old 04-21-2012 | 06:09 AM
Papple's Avatar
Papple
Default Brembo.......
I had a Brembo oversized Rotor & 4 Piston Caliper setup on my 2005 Dyna and it was a night & day difference over stock. The bike has a S&S 124 in it so stopping it was a big problem with the stock brakes.
I've since changed the front end to a Buell unit with the Perimeter Braking system and it really stops you in a hurry. Since I was using the Buell Front Wheel I also used the rear wheel after I modified the rear end and now I have a 190 mm tire back there.
I wasn't aware that there was a Brembo Caliper & oversized Rotor available for my new 09 Dyna so I'm glad you brought this up. I'll be looking to order one as soon as I can confirm that it's available.
I still have the 05 Brembo setup and it's just collecting dust in the shop. PM me if you have any questions.
Ride Safe,
P
Quick Reply: Calipers.."Brembo or PM"
