Calipers.."Brembo or PM"
Old 04-21-2012 | 07:00 AM
nathanw's Avatar
nathanw
I suppose it depends on what you're looking for. The Brembo's are sure to be the better performing of the two, Brembo is the #1 supplier to motorcycle racers in the world. The PM's will probably look nicer/fancier while still offering an improvement over stock.
Old 04-21-2012 | 08:06 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Dyna Year?
What year is your Dyna which is very important to answer this question. In 2006~Current Dynas, HD raised the brake tabs on the sliders to accommodate the 300mm new style rotor. A stock twin cam caliper can be used on a larger rotor than intended.
I know that the 2005 sliders do not have raised caliper mounts so the 300mm/Dresser caliper combo should work but I have never done it.
Brembo Touring 2008~Current. In order to make these calipers work on a 2000~Current baggers with 300mm rotors, HD specified longer mounting on the caliper to raise it so a 300mm rotor can be used. The slider mounting on the dressers have not been changed.
I convert over 2006~Current Dynas to dual Brembos using 300mm rotors as well as dual disk real Brembos that can be rebuilt (dresser Brembos can not) and 320mm rotors.
300mm & Brembos
320mm rotors & real Brembos
320mm/real Brembos on a 49mm fork converted over onto a 2005 Dyna.
Old 04-21-2012 | 09:27 AM
Griff012FLHX's Avatar
Griff012FLHX
Fast Harley....
I have an 08 FXDC
Old 04-21-2012 | 09:46 AM
Just Enough's Avatar
Just Enough
I slid a Craigs List 49mm Vrod front end into my triple clamps and used a Street Glide 18" front wheel, brakes and rotors and EBC double H pads. Two finger stopping now.
Old 04-21-2012 | 12:05 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Originally Posted by Griff08fxdc
Fast Harley....
I have an 08 FXDC
You can not direct bolt up a set of dresser Brembo's onto a 2008 set of sliders and have the calipers work properly.
Old 04-21-2012 | 03:51 PM
missedem's Avatar
missedem
sweet bike . I like the way you have it set up..
Old 04-22-2012 | 10:15 AM
Griff012FLHX
FastHarley
The Motorcyclesuper store is where I saw the set up....
Brembo caliper and 12.6 rotor for 08 FXDC they say directbolt on....
Old 04-22-2012 | 11:11 AM
flyscoal77's Avatar
flyscoal77
PM is American made, looks better and will stop you fast enough.
cycler
07-17-2020 08:38 AM
FatboyDilbert
06-17-2015 05:40 AM
justjoshin84
07-06-2013 05:22 PM
chandler
08-24-2012 04:36 AM
greg64
12-29-2007 09:48 AM
Quick Reply: Calipers.."Brembo or PM"
