Aftermarket Shocks for 06 Streetbob
RE: Aftermarket Shocks for 06 Streetbob
ORIGINAL: Whiffleboy
Another before/after pic for those considering 11inch Progressive 412s. Just put mine on:
You can definitely feel the difference way more than you can see the difference.
Whiff
Whiff
I'm sure you already know this,but based on the amount of the lower part of theshock showing,it looks like you've got your shocks set on the stiffest setting. You'd probably lower the bike another half inch on the lightest setting.
Good Luck
Tom
I had the same question when I put mine on, I ended up turning them all the way one way, sitting on the bike and bouncing on it, then turning them the other way and bouncing on them again. I'm sure I looked like a total idiot, but it was easy to figure out that way. Just make sure no one else is around.
I get [admittedly] retarded when it comes to shock logic, but, if I want it even lower should I have more or less of that black lower part of the shock showing?
Whiff
Whiff
Good Luck
Tom
Man .... you guys sure are tempting me to get some new shocks. The only thing really holding me back is I want 11.5" with chrome tops and black springs...... which means 418's at much higher $$$. May have to pull the trigger on some soon though.
PsTaN
PsTaN
I have Öhlins shocks on my Bob. The difference between the originals and theseis huge! Bike handles much better and carries load better. Shocks are for the FXDX Dyna, but with a few spacers they fitted to Bob also. Length is about the same as are the original shocks.
