chain cams vs gear cams
The only down side(s) to gear drive that I can think of is they will not work if you have crank runout as it will negatively affect the backlash of the cam gears. I'm not certain as to the exact runout limit you can get by with, but I'd guess around .002 max. Maybe some engine builder can chime in to dispute or confirm that number.
One other down side that I've heard of is gear noise. While the slight gear whine may be annoying to some folks, it's music to others.
I put gear drive Andrews 26's in my Duece and the gear noise is an absolute non-issue to me. It's barely noticeable.
if you have an 07 or up twincam, they have the good cam plate and hydraulic tensioners, so they are not a big problem like the pre 07 twincams that had the spring loaded cam tensioners.
The harley spec for crank runout is 0.010, and the limit for gear cams is 0.004 if i remember correctly. So, swapping in may not be all that easy or it could be a direct bolt in if you are lucky.
With the new cam tensioners, going to gear drive does not really give you so much more like it used to with the old tensioners, even in terms of the horsepower robbing that the old tensioners did.
Oh and on a 12 model bike i believe you have the good compensator as well.
Heck, the tensioners are less $ and last longer than my tires . . . so if I look at it like routine maintenance . . .
