Clutch questions
Clutch questions
I'm getting my build dialed in, all the specs are in the sig below. I currently have 640G cams in the build (long story, not my choice) and it is making around 114hp and 100TQ
I am having the cams swapped to S&S 570 that I originally wanted and I'm assuming those numbers will swap, not exactly but a more TQ and less HP which is what I want.
Basically, will the SE clutch spring be enough with the stock clutch to handle this setup or will I need to look into something beefier?
If you have time to wade through 91 pages of this thread - there are countless bikes running that much and more HP on stock clutches with no issues
