Front Fender Clearance?
Old 03-30-2012 | 01:29 AM
Boomer8484's Avatar
Boomer8484
Default Front Fender Clearance?
Im installing a 21" x 2.15" Invader wheel (made by Scotty McLeod of InvaderWheels.com) w/ a Dunlop 402 tire on the front of my 98 FXD and am wondering if there will be enough clearance between the fender thats setup for a factory 19" spoked alloy front wheel.
Old 03-30-2012 | 03:17 AM
slomotion's Avatar
slomotion
You can redrill the mounting holes on the fender for more height
Old 03-30-2012 | 12:33 PM
thedonthere's Avatar
thedonthere
I went to a 21" and didn't have to mess with the fender at all. Why don't you just put it on and see??
Old 03-30-2012 | 05:27 PM
greenstreetbob's Avatar
greenstreetbob
That is slick. Love that wheel.
Old 03-30-2012 | 06:14 PM
p51bombay's Avatar
p51bombay
Yep - or check the specs for each tire on the manufaturers website, the overall height will be listed. And don't forget that most HD fenders seem to be mounted unusually high, mind had enough room to stick my hand between the tire and the fender. If its off, just tape some 1/2" OD tubing on the tire, set your fender in place - mark and drill, I lowered mine so it didn't look stupid.
Old 03-30-2012 | 07:12 PM
darkcvc's Avatar
darkcvc
Just put it on. It is easy. Hour tops.
If it doesn't fit, the front fender holes can be redrilled a little bit to move it up, but not much. It is easier to lower the fender.
Old 03-31-2012 | 01:46 PM
Boomer8484's Avatar
Boomer8484
Well, It all worked out perfectly. I only had to trim the original left side spacer down 3/16" on my lathe and the factory fender dropped right into place.
Old 04-01-2012 | 07:15 PM
darkcvc's Avatar
darkcvc
Very nice.
Mental
05-15-2018 04:17 PM
bigh8840
03-27-2016 12:35 AM
Papa Joe
03-14-2014 12:53 PM
Hessmonster
11-10-2013 09:29 PM
Hogpro
09-20-2012 01:02 PM
