12' FXDB downshifting funk
Before I take it in I need a little advice. I just bought a 2012 street bob. I put forward controls on it and it was fine the first 2 days of riding. The only problem was it was hard as hell to get it into neutral. Today when I took it out I didn't have that same problem getting it into neutral but now when I down shift it doesn't want to catch. Even when I release the clutch I have to tap down about 3 times to get it to catch. It wasn't every time but it must have happened about 15 times in a 2 hour ride. When the problem shows up its not lost in gears, it doesn't grind it still smooth when I do get it in. I can probably explain better if I get specific questions. I left the primary but its in a secured position which doesn't interfere with any of the moving parts. I need to take it in for 1k service so I'll ask then but any help now will be appreciated. Thanks
SC Longhair is referring to the clutch pack itself - which is seen when you remove the derby cover. You need to adjust your clutch and I would bet your linkage is not correctly adjusted either. You need to get your bike's Service Manual and Parts Catalog - both of which are readily available on Harleydavidson.com
Here's a video from Jerry Fishel who owns Vicious Cycles in Santa Clara, Utah on how to adjust the clutch pack: http://www.ehow.com/video_2330184_ad...utch-pack.html
