06 Lowrider cutting out
Old 03-28-2012 | 04:43 PM
jrounkles's Avatar
jrounkles
6th Gear
Default 06 Lowrider cutting out
I have an 06 Lowrider that cuts out when cruising through town between 20-45 mph. It also idles a little high (1500-200 rpms) but will drop back down to just below 1000r rpms if I sit for a bit.
The only thing that has changed is replacing factory exhausts with Screaming Eagle slip-ons. Any ideas? Remapping issue?
TIA
Old 03-28-2012 | 06:50 PM
Mascman's Avatar
Mascman
Make sure you have the 25° injectors with the proper download.
The injector issue was a problem for the 2006 bikes...do a search if you are not familiar with that issue.
grizzly
10-29-2007 07:44 PM
Custom07RKC
03-10-2007 11:43 AM
RockyTopRider
02-25-2007 10:48 PM
AceHog
06-27-2006 07:50 PM
chopperchuck
03-07-2006 12:14 AM
Quick Reply: 06 Lowrider cutting out
