Dyna Wideglide floorboards
Old 03-27-2012 | 10:35 PM
sandpacker's Avatar
sandpacker
Default Dyna Wideglide floorboards
Ok I asked this question befre ,but I think in the wrong place..
Does anyone make full sized floorboards to fit a Dyna WildeGlide? My bike is a 08.
I heard a rumor that switch back floor boards will fit perfect but rumors are just that.
I dont care about passanger floorboard! I love my dyna but Harley or someone should have floorboards. My feet on long trips feel as if there going to fall off the pegs.
Old 03-28-2012 | 01:47 AM
SURFOR Chop's Avatar
SURFOR Chop
Should work for you ... forum member Harley Tim installed them and posted part numbers of everything one needs ... pay special attention to the notes ...
Only caveat ... your exhaust heat shield may need to have a notch cut to clear the bracket ...
Originally Posted by Harley Tim
OK, here I go,
I't's taken about a month to get in all the parts but, I think the wait was well worth it. These are for the '12 FLD footboards and, the people I hang with say " They look like they've belonged there the time."
Here 's a list of P.N.'s and prices as they applied to me, having an'06 Superglide W/Fwd controls and Vance & Hines Bigshot exhaust.
For the footboards:
54165-12 SUPPORT, right footboard $ 52.72
54172-12 SUPPORT ASSY, right footboard $ 68.75
54173-12 SUPPORT, left footboard $ 52.72
54174-12 SUPPORT ASSY, left footboard $ 68.75
50621-06 FOOTBOARD ASSY w/pads $ UNK (See note #3)
50614-06 PAD, footrest $ UNK (See note #3)
7354 LOCKNUT (4) $ UNK
50674-05 BOLT, shoulder $ UNK
4512A SCREW $ UNK
For the brake:
38157-12 BRAKELEVER ASSY $ 111.00
42416-06 PAD, brake pedal $ 4.25
4997 SCREW $ 4.00
38160-12 CAP, brakelever $ 10.95
38161-12 PUSH ROD $ 72.56
42665-03 PIVOT SHAFT $ UNK. (See note #1)
For the shifter:
33789-12 SHIFT LEVER $ UNK. (See note #2)
34887-06 SHIFT ROD $ UNK. (See note #2)
6702 WASHER $ UNK (See note #2)
7736 ACORN NUT $ UNK. (See note #2)
If you have mid-controls:
2882W BOLT $ UNK (See note #4)
7710W NUT $ UNK (See note #4)
34639-93 RETAINER $ UNK (See note #4) For ’96-’00 models
34639-01 RETAINER $ UNK (See note #4) For ’01 and later
34640-93 COVER, Shift shaft $ UNK (See note #4)
3231B SETSCREW $ UNK (See note #4
NOTES:
#1; If HD Fwd controls are already on the bike, the existing part is the same P.N
.If NOT HD Fwd controls, OR is HD mid controls, this part may be needed.
#2; These parts are needed if the bike has mid controls. If HD Fwd controls are already on the bike, these parts are not needed.
#3; These are Stock FLD (Chrome) footboards and come with the PAD, I Opted for P.N. 51322-08 FOOTBOARDS (Black) from the ’12 HD custom book (I’m not real big on chrome) and my parts guy gave me a set of stock “take off” standard PAD, footrest.`
#4; These are parts listed as an option to removing the outer and inner primary cases to remove the existing shift lever shaft and, cap the holes.
Sorry, no pics yet, soon to come. Best wishes Tim
Here's a thread of another member who installed the floorboards on a Fat Bob ... https://www.hdforums.com/forum/dyna-...n-fat-bob.html
Good luck ...
R/
'Chop
toku58
06-02-2013 09:39 AM
DCLXVI
12-23-2011 11:46 PM
hell hound
11-11-2011 07:57 AM
Mr Vintage Machine
06-13-2007 05:17 AM
Quick Reply: Dyna Wideglide floorboards
