FXDF: Are the rear turn signals also running lights?
As far as my research can tell, no law against leaving the amber lenses installed. They even sell the module for $10 less without the lenses. Rear blinkers in most states can be red or amber, front can be amber or clear.
I leave the amber lenses on as they stand out in traffic much better.
Thanks for the reply. I have been thinking about the run/turn/stop module as I don't think the under fender brake light gives enough of a display as a running light at night.
For what it's worth, in MD (2010 Maryland Code TRANSPORTATION TITLE 22 - VEHICLE LAWS) say:
- motorcycles do not have to have turn signals
- front turn signals can be white, amber or any shade in between
- rear turn signals can be red or amber or any shade in between
- stop lamps (brake lights) can be red or amber or any shade in between
My guess is you'd be better off with a red brake light and amber turn signals as those colors are what drivers are conditioned to understand. So, if you have a run/turn/brake controller on your turn signals, its probably better to keep them amber. I also think it could be beneficial to stopping as the driver sees both red and amber - not common and, perhaps, more likely to get their explicit attention. JMHO.
FMVSS 108 which most states have adopted as their standard requires that tail or stop lamps be red - this is why the kit comes with red lenses.
Anyone have a part number? is there a way to do this without the module?
Here you go.
Auxiliary Brake Light / Running Light / Turn Signal Conversion Kit - Bullet Lens Style
Turn signal module adds an auxiliary brake light and running light function to your existing turn signals for auxiliary rear lighting. Red lenses glow when the headlamp is on, and increase in intensity when brakes or turn signals are activated. Easy-to-install, the kit simply plugs into your existing wiring harness. Red turn signal lenses are included. Meets DOT requirements.*
69462-06C
Bullet Lens Style
Fits '02-'03 XL, '02-later DynaŽ (except FXDXT and '09-later FXDB and FXDWG) and '02-later SoftailŽ (except FXS, FXSTD/I) models with stock bullet-style turn signals. (NOTE: Not intended for use on '04-later FLHX, FLHRS, FLTR or FLHTCSE models, '05-later FLSTN models or models equipped with Bullet Turn Signal Bar Kit P/N 68615-04 or 68617-04. If installed on these models, the system will function properly but will not meet the DOT minimum separation requirements for a red tail light to red turn signal.)*
MSRP US $59.95
69462-06C
Bullet Lens Style
MSRP US $59.95
www.chromeglow.com has some good LED turn sigs for the bullet style housings. The leds are much brighter than the stock bulb and are rated to last almost forever lol
