How do you remove chrome band from battery cover
03-24-2012, 10:22 PM
Anyone know how to remove the chrome band from the battery cover on a 2010 FXDC? It doesn't have the 3 tab thingies that you simply squeeze with pliers to remove it. It has what looks like 2 chrome rivets.
Also, the chrome band on the fuse panel cover. How does that come off? Is it held on with adhesive or adhesive tape?
03-24-2012, 10:40 PM
I just used a heat gun in the back to soften the double sided tape and it came right off. The I was able to reinstall it without new tape.
03-24-2012, 10:44 PM
What P69 said.............. and if the one has rivets, you need to drill the head of the rivet to allow the band to pop free.
03-24-2012, 10:52 PM
I think they are just studs used for alignment not rivets. Use a heat gun or hairDryer and see if the adhesive will losen up
03-24-2012, 11:35 PM
Heat gun or hair dryer and fishing line works good
03-24-2012, 11:42 PM
Quote:
Originally Posted by
pontiac69
I think they a just studs used for alignment not rivets. Use a heat gun or hairDryer and see if the adhesive will losen up
Ditto, the one i have is just alignment tabs and double sided tape
03-25-2012, 09:37 AM
04-20-2012, 07:31 AM
Not sure what one you have but the newer style has 4 Allen bolts that hold it on. I know because I just removed the trim ring
schumacher
07-26-2011 06:50 PM
JT-FXDL
05-12-2011 02:15 PM
Max10
05-11-2010 08:29 AM
purvissp
03-06-2010 04:51 PM
stanleyc
07-12-2007 06:52 PM
2010 ,
band ,
battery ,
bob ,
change ,
chrome ,
cover ,
custom ,
dyna ,
fat ,
glide ,
low ,
piece ,
removal ,
removing ,
rider ,
super ,
wide
