Throttle return spring weak??
Old 03-18-2012, 08:57 AM
convincor's Avatar
convincor
convincor is offline
Default Throttle return spring weak??
Wife just recently picked up a 08 FXDL with 20k the on the clock..
Question is, the throttle spring tension is very weak. It is almost effortless to twist the throttle. So riding down the road she hits any bump it effects throttle.
Can the spring on the throttle body be replaced??
Old 03-18-2012, 11:27 AM
Mike650's Avatar
Mike650
Mike650 is offline
i dont see why it couldnt. see if the dealer can sell you just the spring.
Old 03-18-2012, 11:43 AM
convincor's Avatar
convincor
Looking up parts in exploded view they dont show the spring separate. That actually don't even show a part # for the throttle body itself...
Old 03-18-2012, 12:02 PM
lo-rider's Avatar
lo-rider
lo-rider is offline
You're trying to change the bike to make up for an operator malfunction. There is nothing wrong w/ the throttle spring. Adjust bars and rider position so her arms don't flap up and down when she hits a bump.
Old 03-18-2012, 12:15 PM
convincor's Avatar
convincor
As I said. The spring is WEAK. Has nothing to do with the rider.
If it were to take 5 lbs of pressure to rotate the throttle, this bike only take one pound compared to what my superglide was.
Old 03-18-2012, 08:45 PM
cacolade's Avatar
cacolade
cacolade is offline
sounds like the cables are out of adjustment
Old 03-18-2012, 09:15 PM
2012fxdc's Avatar
2012fxdc
2012fxdc is offline
yeah after i changed my bars, i adjusted my one of my throttle cables for that problem
Old 03-19-2012, 05:21 AM
convincor's Avatar
convincor
Adjusted the cables yesterday before we went out. Made a little difference and enough to not worry about it. She's happy with it so..
Old 03-19-2012, 01:00 PM
Screamin'beagle's Avatar
Screamin'beagle
Screamin'beagle is offline
Stage III
Yep, wife is happy, Convincor is happy......... No "flapping" arms here.
Old 03-19-2012, 07:48 PM
Just Enough's Avatar
Just Enough
Just Enough is offline
On the EFI Harleys the beginning progression of the throttle opening is pretty aggressive and takes a while to get use to. I'm surprised it could be programmed or the cable wheel re-shaped to make it behave like the carbed bikes.
Quick Reply: Throttle return spring weak??
