I'm a rock. How do I change the rear pads?
Old 03-10-2012, 06:14 PM
p51bombay's Avatar
p51bombay
p51bombay is offline
Originally Posted by orange52
Knowledge is power!!
And so is a shop manual.
Old 03-10-2012, 09:04 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
Old 03-10-2012, 09:07 PM
DCLXVI's Avatar
DCLXVI
DCLXVI is offline
To push the piston in you apply pressure on the pad itself. Change the inboard ones first by pulling the pin only far enough to get the inboard pad out. Once you replace the inboard pad insert the pin and apply the brake. This will hold the new inboard pad in place. Now push the outboard pistons in and remove the pins all the way. This will allow you to replace the outboard pads while holding the inboard pads in place.
vicsponjr
03-16-2016 09:25 AM
Fuzzy1950
03-28-2015 03:44 PM
Burstbucker
Wheels/Tires
03-20-2012 09:10 PM
grizzwold
EVO
08-23-2011 06:10 PM
wrknman
03-19-2008 01:26 PM
Quick Reply: I'm a rock. How do I change the rear pads?
