Spring mods have started!
making tracks! got home from the shop yesterday, got the rear tire back in lined up and bolted down, installed the new clutch cable and gasket on the housing, new throttle cables are on, wrapped all the cables prior to install, they look great! Got the battery box with the horn on the back bolted in and tested... BEEP BEEP.... then drained all the fluids out of her and spent some TLC time cleaning all the road grime and oil that is all over the place from the faulty gasket on the oil cooler sandwich plate... getting there! just have to mod the pipe (and support bracket), replace the oil cooler lines, replace the oil cooler sandwich plate gasket, install new fluids, install new battery, and check for the stutter (cleaned all the sensors though so that may be it or the bad battery)
fresh clutch cable wrapped
wheel installed
my bro popped by to give me a hand on his new Z1000... (we have nt done much to this bike.... YET)
wheel installed
