Speedo conversion
Speedo conversion
OK, here is the project. I have a 03 FXDP and want to remove the fugly dash console and replace it with a dash/speedo from a WG. On the FXDP the wires for the ignition switch run on top of the tank, under this cover. On the WG trim panel there doesn't seem to be room for the wires. On a stock WG, are the wires run under the tank and in through the front of the speedo console? Also, the connectors for the handlebar wiring are under the fugly console. Is this where they are on a WG or are they located somewhere else? Thanks for any help on this.
2003, article, conversion, dash, dashboard, davidson, fxdp, harley, motorcycle, powered, speedometer, tire, trailer, wiring
