rocker breather assembly kits
The new breather assembly is included in the recent gasket kits, and is usually used to replace the plastic breathers. If you have aluminum breathers and have gaskets from the older sets, you can use the umbrella and gauze in your breathers. If you dont have gaskets, use the new breathers since the gaskets are glued to the stamped steel.
