lowrider indicator lamp assembly - complete kit?
Hi all -
Working on my 2003 lowrider. Wanted to know if anyone knew if there was a pre-assembled kit for the indicator lamp assembly available to buy or do you have to buy all the parts and assemble?
The assembly itself is comprised of the following parts (pulled from parts manual):
Turn Indicator(x2)............................Factory P/N: 68021-92A
Hi Beam Indicator.............................Factory P/N: 68023-92A
Oil light Indicator .............................Factory P/N: 68020-92A
Neutral Indicator .............................Factory P/N: 68024-92A
Bezel, Indicator Lamps.......................Factory P/N: 68513-92
Trim, Indicator Lamps........................Factory P/N: 68516-92
Socket Housing, 10-way (black)..........Factory P/N: 73160-96BK
Terminal, socket (10)........................Factory P/N: 73191-96
Well - i hadnt realized you could pop the trim ring off.. in frustration i ended up cutting all 10 wires. Im in the process of adding new handlebar top clamp (with indicator light slot on the top of it) and with the bezel/trim in place, it would not fit into the receptacle - hence the cutting. Dumb yes i know and now about 70 bucks out of pocket - just priced all parts from latus harley - comes out to $69.89 + shipping.
Anyway, good to know so the next time i have to make any changes ill know the correct way of doing it. Thanks!
