Is it Hard to Install new handlebars?
Go for it. You can do it. IF you don't need longer cables and wires then it should be a cinch. Most importantly, get the service manual. Its worth every penny. Between the service manual and you tube videos you can do it. I put 17" apes on my FXDB this winter, internal wiring and all. It wasn't bad at all. If you do have to get longer wiring i recommend calling the guys a Hill Country Custom Cycle. Tell them your bike year amd model and how high your bars are and they can send you everything you need.
Its not hard get a service manual and plenty of threads on here along with you tube videos it is pretty straight forward I did mine a couple of months ago first time took me about 3 hours I had to change cables and all, the hardest part the most aggrevating part to me was putting the connecters back into the back bone lol!!! Really tho its simple, You Can Do IT!!!!!!!!!!!!
Brake lines aren't bad. Take them off and collect the fluid. Wipe off the spillage cause it'll eat paint. Put the new ones on and with the bleeder loose, pour into the reservoir and pump the brake until it comes out solid and tighten it up. You should see bubbles come up as you pump your brake lever. I had an issue because I couldn't get one air bubble out. I needed to end up using a Pump and it was all good.
Yep, Brake lines is the least of your worries. Bleeding brakes is a piece of cake. When I flushed mine, I was surprised how fast it flowed out.
