Iso-Grip Insall Help
So last night I went to install my iso-grips and the adjusters for the throttle and idle cables will not move. I was able to get the jam nuts loosened but not the adjusters. Although they don't look rusted, I'm assuming there's corrosion in there. And, there's really nothing to grab to keep the line from twisting when trying to loosen. I'd appreciate some tips to get them loosened?
Thanks,
Thanks,
I think we're talking the same thing. Problem is once what u call the lock nut is loosened, there is nothing to hold rigid when trying to loosen the longer adjusted nut. I guess my question is should the long one be finger adjustable. Goes back to my original dilema of it not moving. I'm going to hit it with WD40, was just curious if long sleeve should come off using fingers instead of wrench.
Here this video may help with the whole process.
http://www.ehow.com/video_5538516_re...bar-grips.html
