Tire clearance - how much do I need?
I'm working on putting a fatboy front tire on by Street Bob. It'll be the 140/75R17 Dunlop D408F which I beleive is actually 145mm wide at its widest point.
I've been measuring the space between the fork sliders and it's 155mm mostly with a small section about 160mm where there is a sort of shallow cutaway in each slider. The wider part is round about where the sidewall of the tire will be although I can't say for absolute certain being as I've not had the front wheel built yet.
So is 10mm clearance enough, i.e. 5mm per side between the tire and the sliders?
On Metzler's tire site they specify .25" clearance each side and .5" at top of the tire. Scroll to the bottom of this link.
Your clearance would work out to about 3/16" each side.
http://www.us.metzelermoto.com/web/p...s/default.page
