Auxiliary turn signal mirror
yes and they require a little converter harness (with PC board) that takes the standard 3 wire front turns to 2 wire. The leds in the mirror light full with the driving lights and blink on/off with the turns. The converter basically turns the lights on-off when the turn signal wire toggles.
If you didn't get that harness its expensive ($50 ea and ya need two)
You could just run turns and forget the driving lights, but if you remove the stock ones you lose lighting...
I'm sure if you ask some guys that know electronics they could tell you how to set something up like this for a LOT less than the $100 Harley is wanting to charge...of course it won't be as "tidey" I'm sure.
Link to Item
Link to Instructions with Part Numbers
I have the harness on mine and just went down to the garage to remove the bulbs from the stock signals to see what happens...
Well, the sigs flash fast but after turning them on/off a couple times they settles into the regular speed... Looks like I'll be unplugging them from the harness and relocating them to the garbage!
OP, if you want the running lights the harness makes it very easy, just plug and go!
1960lespaul
04-13-2012 08:37 AM
