how tough is it to do your own oil changes?
Old 12-18-2006, 06:53 PM
fisherguy54's Avatar
fisherguy54
fisherguy54 is offline
Default RE: how tough is it to do your own oil changes?
I bought a tray from jp cycles to catch the oil from the filter and it woks pretty good. I bought a filter wrench from the motor company after trying a cheap one from a parts place. Worth every penny. A few dollars for a couple of tools will save you lots down the road.
Old 12-18-2006, 07:43 PM
MasterRye's Avatar
MasterRye
MasterRye is offline
This is an awesome trick, much less messier to the bike.
If you cut the bottom of a 2-liter bottle and cut a wide slit on the side of the bottle to get your hands in, this will slip around the filter so you can take it off and the oil will go in the top of the capped bottle. This is much easier than using tin-foil shaped to funnel oil to the oil bucket.
Old 12-18-2006, 07:46 PM
Sandhog's Avatar
Sandhog
Sandhog is offline
LMAO
I can see it taking more that two to change the oil.It really all depends on how strong you guys are.
Heres MY method.
1.Buy the oil and filter from the dealer of your choice.
2.Buy a case and a half of Becks beer from the beer store of your choice.
3.Call up your buddies and repeat the following to the letter"Hey Buck,I gotta a casepointfive of Becks on the bench,ICE COLD.Wanna go ridin meet in my garage at noon."
4.Place the tools on the bench atop the beer around 11:45
5.No self respecting bro would drink a mans free beer without lending a hand changing the oil.Fake an end run into the house for an emergency phone call or whatever.
6.The oil change will be done when ya get back.
Itll only work once.............
Old 12-18-2006, 08:57 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
ORIGINAL: ameristo
I guess I must have misunderstood. When I change oil I do the engine, transmission, and primary all at the same time in which case you will have to hold the bike in an upright position to get the proper oil level in the primary. I would differ that being a 10 minuite job.
[IMG]local://upfiles/6102/5BDCD61D4EC644BE97EB62A3AC0A9E8C.gif[/IMG]
Put a 1x8 piece of wood under the jiffy.......the primary & trans on my 06 Dyna each take 1 quart...sit on the bike and rock back & forth sideways with the drain pan underneath and all the oil will come out....no brainer forget about the oil level...1 quart out---1 quart in......the engine takes 2.5.......done........but probably more like 30 -45 minutes to save $100 and use top shelf oil. But I'm using redline oil in the primary & trans which will easily go 15000 miles. Well worth the $8 per quart.
Old 12-18-2006, 08:58 PM
Whiffleboy's Avatar
Whiffleboy
Whiffleboy is offline
ORIGINAL: MasterRye
Don't you guys mean 1-liter bottle???? I used my Mobil 1 Gear Oil bottle. 2-liter won't fit in there.
Whiff
Old 12-18-2006, 10:53 PM
misfit's Avatar
misfit
misfit is offline
Oil changes are easy, use the manual. I will say that the most challenging thing is not spilling oil when removing the oil filter at least on my 06 SG with the CA emissions cansiter and forward controls..
[IMG]local://upfiles/10558/913A9E64E2794E7490E3AB7985FE3D62.jpg[/IMG]
Old 12-18-2006, 11:00 PM
CSI's Avatar
CSI
CSI is offline
ORIGINAL: Sandhog
LMAO
Heres MY method.
I don't care WHO you are, that THAR is some funny chit.......and TRUE !
Old 12-19-2006, 03:17 PM
Renegade's Avatar
Renegade
Renegade is offline
Very easy...just try man. Read your owners manual or go to the forum on oil etc here at HDF.
Old 12-19-2006, 05:27 PM
Draggin S's Avatar
Draggin S
Draggin S is offline
Absolutely takes two people..........One to change oil and one with big tit$ to hold your beer and rub your neck while you work...............................
Old 12-21-2006, 02:51 AM
kjriv's Avatar
kjriv
kjriv is offline
hehe..now THATS how you do an oil change...
Quick Reply: how tough is it to do your own oil changes?
