Good deal on a Deka Magna Power battery
Check the date on the battery and make sure it's not an old one that has been sitting on the shelf a while. There is a letter and a number on a sticker on the side of the battery with a cutout on the box so you can see it. The letter represents the month (A-M , they don't use the letter i) and the one digit number is the year.
Mine was a M1 so it was made in December 2011.
Glad I could help. I like passing along good deals when I find them.
Dumb question, I wanted to see if this battery was the same P/N for a 06 street glide but adavnce only list cars, and the battery site doesn't list motorcycles. how do I check for the right P/N? I need to order one ASAP.
I searched and figured it out. I need the ETX30L, cost about $128.00 but with $35.00 off it's $98.00. Thanks.
Correction I just found another code to save you $35 making the battery $54.99.
Use code RAF7JA1102
Also if you don't believe they are made by Deka check out this link http://www.leschbatterysales.com/dek...m-batteries-1/
Use code RAF7JA1102
good find Pig.
does it fit into the battery compartment with no issues??
I went to Advance and measured their battery
height and width look good.
front to back is 4". seems like my compartment is only 3 3/4" deep.
so - no problem??
