Extended fork tubes?
I cut them to exactly 6” I am not positive that is the correct length. Didn’t even think twice honestly. 6” longer tube 6” of spacer?.
Also put recommended amount of fork oil for original length.
I appreciate the feedback
It would be good to calculate the volume of your forks additional volume. so, 39mm x 6":
36mm ID x 152mm length = 154,717 Cubic Millimeter calcs to putting an extra 5.25 fluid ounces in each fork.
Dave
[QUOTE=TOE_CUTTER;19797311]Do you have the original spacers? A good starting point would be the original spacers + 6".
Dave there were no spacers in the forks when I disassembled them to do the seals.
Just rebuilt with +6” tubes and added 6” spacer.
so length of tube x diameter gives me my tube volume. How do I calculate the oil amount from that number?
[QUOTE=Paul Bowes;19797347]
I put a comma instead of a period on the 154,717. Should be 154.717. The basic formula for calculating cylinder volume π 𝘳² 𝘩.
When you cut the spacers and put them in without your front wheel touching the ground, they should be sticking out of the top of the forks 1/2" to 1".
Dave
Dave
I would put the spacers in the tubes and then fill them to the factory recommended level, fish the spacers out, install the springs, spacer and caps. Saves having to calculate the volume of the spacers, which should be subtracted from the amount of oil (after you add the amount for the additional length).
And if not, would it make more sense to just disregard them in determining the amount of oil?
also, is 6” the correct spacer length for 6 over fork tubes? Makes sense to me but like a lot of things I am not 100% sure.
since the spacers are on top of the springs are they even in the oil?
