Anyone tried the high output aux horn (not the air horn)?
Has anyone tried this horn or heard it somewhere?
I am thinking about putting the "classic" horn on my bike instead of the standard horn. But the website indicates that you should not use this horn by itself. They also have a high output horn that is described as being an auxiliary horn. I am wondering if I added the high output horn, if I could use the classic instead of the regular. Surely two "auxiliary" horns are as good as one standard horn????
The part number for the high output horn is 69181-02A. It mounts between the downtubes.
Kevin
Kevin
http://www.cruisercustomizing.com/de...r_1100_Classic
tyr the Minibeast self-contained air horn. It is easy to install and is very loud. The whole thing fits behind the chrome cover so there is no need to hide a tank or compressor.
I was actually hoping to put the classic horn where the stock horn goes. I just don't care for the horn being there. I've replaced the cow bell for a round horn cover but still don't like it. I thought I might actually like the classic horn mounted in the stock location OR mount it on the springer and leave the jugs bare on the left side.
But I appreciate the pointer, I'll check it out. I've heard of the mini beast before but I haven't looked into it. I might be interested, especially if there are some alternate mounting options.
Kevin
Kevin
