How many out there using True Track?
Maybe I'm just not used to the longer wheelbase, but coming from a Sporty, I find I really have to pay attention to turns or I'll end up in another lane. Also, if I get into a rut or drainage "V" on a road, the rear tire wants to take over and move the bike where ever it wants to go. Also feels like the steering head bearings are loose when hitting rough roads, although I know they're not. Will the True Track fix these symptoms, and if so, HOW COME HARLEY DIDN'T PUT IT ON THE BIKE TO BEGIN WITH??
I have the similar system, Sputhe. It really helps, as Im sure a Tru trak does as well.
As many have said, the problem is the rear tire is connected to the back of the tranny. and it wiggles. These things, make your bike feel like a solid piece instead of 2 things hooked together. Yes it should have been that way from the factory. You get more stability in turns and thru grooves and windy situations. Definitley get one.
+1 on the True Trac
I wonder if it's a Wide Glide issue. I have no stability enhancement modifications and my Super Glide performs flawlessly. I ride a great deal in the Sierra Nevada twisties, putting the suspension through about everything you can throw at it. No chicken strips on my tires and no issues otherwise.
My first inclination would be to start looking for the cause, and forget about applying band-aides to cover the symptom. ie. tires, shocks, mounts and so on. But maybe it has something to due with the dynamics of the Wide Glides?
I put a True-Track on my Fat Bob about three years ago because I experienced a bad wobble in long turns and also an unsteadiness when blasted by crosswinds during really windy days (possibly aggravated by the solid wheels and saddlebags). After a week of really windy days and a lot of research on this forum I took the plunge for the True Track.
Handling was improved once the True Track was installed. I never had the wobble on turns again. And the bike handled much better when battered by strong crosswinds. This is how the bike should come from the factory.
Wait, you mean bolting the swing arm to the rubber motor mount instead of the frame is a bad idea...... lol. Yeah, I guess it is! The True Track or the Sputhe is a excellent way to help stabilize the bike. Yeah, tires, upgraded suspension, steering head adjustments and bearings all play a part, but a chassis stabilizer like a True Track is an excellent device (investment) to help shore up the bike. Its not that much money, and compared to what I have spent just on chrome, it was well worth it.
I just happen to put a Sputhe stablizer on last night - I also just got a new set of Metzler tires. I only got to go for about a 10 mile ride today but between the two (tires & stablizer) the bike feels great. It's hard to describe but the bike just feels more solid. I was a little reluctant about buying the stablizer because I'm not an aggressive rider but I can definately feel the differance.
Jimmie
Jimmie
