2011 Wide Glide Upper Belt Guard Removal HELP!
Thank you all so much for the advice. I woke up early this AM determined to get the belt guard off. I did strip it too far last night so I tried a couple larger allen wrench heads while heating it up. No dice. I ended up trying to drill it out with my cordless drill. I drilled a hole through the whole bold and it is still in there. I worked on it for at least an hour and a half this morning trying different things. I'm gonna take my console cover up to the dealer today to get sent off to who they contract their powder coating with. I'm gonna ask the service department and see what they say. My problem is it should not be this hard to get a belt cover off. I know I stripped it and probably made it worse by what I did this morning but now its gonna cost me money just to get the guard off. This kind of thing drives me nuts with HD parts.
when using allen wrenches, drivers or torx's, first make dam sure that your using the right size. dont grab a .mm instead of an sae (been there) dont grab a 25 torx when it required a 27. make dam sure the allen or torx tool is seatted all the way down into the fastener. always keep downward pressure when busting things loose. And when you get things apart dont "F" it up by over tightening. a torque wrench can be your best friend
+1 Solid gold advice! My FXD has a mixture of SAE and metric fasteners. Allen heads are a bear because most allen wrenches don't have the size stamped on them. When it comes time to put tools away, be really careful to return the allen wrenches to the correct pouch. "Usually" the only way to strip an allen head bolt is by using the wrong size (SAE/metric) wrench. ynots advice on torx head is right on aim too. You can often remove a 27T bolt with a 25T wrench, they're that close in size, but you'll strip the bolt head eventually. I have some fasteners due for replacement... for the same reason. Used to be a guy could eyeball a hex head bolt with 100% accuracy. Now with metric, allen, torx heads, it's a crap shoot and I often make return trips to the tool box.
Protocol
09-16-2017 09:01 AM
Col.Squirt
08-28-2010 08:40 PM
