I really need some help with a sticking throttle.
I just replaced the stock grips on my 2011 fat bob with the kuryakyn iso grips. The throttle side works freely until I tighten the housing, then it sticks. I mean it won't return to idle when I release it. When I hold the housing tight with my hands, the throttle is fine. It only sticks when I tighten the housing. I can't figure out where it is binding. Anyone have this problem or know how to fix it? I have adjusted the cables.
Robterra posted about leaving a little gap at the end of the bar. Unscrew the cap and see if there is some space between the end of the grip and the end of the bar...you don't want any interference there. I installed ISO TB grips a few weeks ago. They aren't as 'free' as the old ISO grips were, but those had many working-hours on them too. Clean the bar and grip before using graphite. It will do the job once it gets worked in. It is a powder so be careful with that stuff.
Ah Ha! See you fixed it. Good show!
![Icon Bricks](https://www.hdforums.com/forum/images/smilies/icon_bricks.gif)
My 2010 FatBoy had a defective throttle that would not return properly right from the dealer. I backed out the throttle lock all the way but to no avail. Amazingly, HD replaced it for free and the bike was a several days old already!
