I really need some help with a sticking throttle.
Old 01-15-2013, 02:51 PM
jayb1367's Avatar
jayb1367
jayb1367 is offline
Stage II
Originally Posted by Drdriller
I just replaced the stock grips on my 2011 fat bob with the kuryakyn iso grips. The throttle side works freely until I tighten the housing, then it sticks. I mean it won't return to idle when I release it. When I hold the housing tight with my hands, the throttle is fine. It only sticks when I tighten the housing. I can't figure out where it is binding. Anyone have this problem or know how to fix it? I have adjusted the cables.
Send the grips back they are defective. The edge of grip is warped. It is not perfectly round and level. Remove the grip and follow edge with your finger and you could feel and see that it is warped.
Old 01-15-2013, 03:38 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
I just sent my ISO grips back last week for the same problem. I looked inside the throttle grip and saw some hard glue like substance towards the end of the grip! Tried to chip it off, then said to myself, this is totally unacceptable and I am not going to try to fix their problem. I am suppose to get new ones tomorrow, I will update if I keep them - thinking about Performance Machine grips.
Old 01-15-2013, 06:06 PM
128auto's Avatar
128auto
128auto is offline
Please don't over look, sometimes it could be the throttle thumb screw being too tight. Take a look! Back off a couple turns and see.
Old 01-16-2013, 05:37 PM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
Got my second set of Kuryakyn ISO grips today and first thing I did was look inside the throttle side grip and sure enough another glob of hard glue near the end of the grip. Not as bad as my last set but not acceptable to me, the last thing I want is a sticking throttle so I am done with these grips.
Old 03-25-2013, 07:58 AM
lowriderboy's Avatar
lowriderboy
lowriderboy is offline
1st Gear
I am having the same problem with my transformer grips. I have already loosened the thumb screws and tried sanding the grips and housings and still no luck.
Old 03-25-2013, 08:30 AM
HD Pilot's Avatar
HD Pilot
HD Pilot is offline
I went with the HD Get-A-Grips, no glue, easy install.
Old 03-25-2013, 06:32 PM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
i bought arlen ness port hole grips. Man they r so nice. Quality built. Had no issues what so ever on my fxdf. went on in 35 min both sides not a single issue. Maybe i lucked out but right side slipped right into throttle housing with ease.
Twospot
06-29-2016 07:33 AM
amkaos
09-27-2015 12:20 PM
geost
12-27-2014 08:36 AM
Ramman911
General Topics/Tech Tips
07-05-2014 10:38 AM
sajackson
10-11-2011 09:21 PM
Quick Reply: I really need some help with a sticking throttle.
