09 rear touring rim on 08 bob?
so looking at ebay and finding 16x5 touring rear rims. what would i need to make it work. or could i bolt it right up?
reference of wheel ----- http://www.ebay.com/itm/HARLEY-DAVID...item4cfde0a551
and what is the big dish looking thing on one side of the wheel in picture 2. attached to the center of the wheel?
I actually did this. The big dish looking thing is damper assembly that came out 1/2 way through 2007. You cannot use the hub. You can relace your hub to it. I took about three threads off each 17" Dyna spoke to slightly shorten them to fit the 16 inch rim. I used it all last year with no problems and it maintained it's true just fine. I do run the 180 WWW Touring tire.
