Reckless Cheap Fairing
here is mine using quick detach mounts. you will just need 1" spacers to mount on all the clamps, if you have 49mm mid glide forks. i just cut the vertical part of the stock bracket off. no need to take it to a shop, its not hard and you will need to test fit it to your forks anyways
vertical part?
the brackets just look like the letter P. sorry dont have pics of it before i cut it up but i just cut the long vertical section off. you can get some spacers at any hardware store. a steering damper smooths out and slows down steering response to bumpsteer and with the added weight of the fairing it will slow down steering response in corners reducing the tendency for the front end to fall away
Have you looked at a Road Glide twin headlight fairing? The headlight insert portion might take some massaging to work with the Fat Bob duals but I would think it's doable with some creativity. Check out the pic of the 2012 Road Glide with twins and you'll see what I mean http://www.harley-davidson.com/en_US...tml#/c/gallery
I think those are dual 7"s in the Road Glide but with a new insert or something to sort of wrap the twin Fat Bob light I would think the fairing itself could come out looking like the new thing for Fat Bob's
https://www.denniskirk.com/drag-spec...it.pH58683.prd
A steering Damper is basically a shock that helps to stabilize your steering structure against minor sudden and sharp movements. (such as minor wind steer or small bumps in the road)
If you remember about 10-20 years ago you had to constantly move your hands back and forth on a car steering wheel to keep the car on the road. It became second nature to most people and you probably never noticed. A few years back they started installing these on the hub assemblies of cars to keep you from having to do that as often. The result is the ability to pretty much drive without hands 80% of the time.
Would you like to know more?
I am assuming the look depends on the light style. The old pickup style the early Harley's used and which is the same as the new Fat Boy uses isn't very deep. Its just a shallow bucket with a lens cover on it. The only way to get it to stick out farther is with an extended mounting block or a deeper bucket like a bullet so what your probably seeing is pics of a Soft Tail, Fat Boy etc with that kind of light and a fairing with an opening that is slightly deeper than the light sticks out from the triple tree mounting plate. It seems to me a lot of people don't like the look of a 7" bullet with no fairing and they usually get a new light long before deciding on getting a fairing. That's why I got a bullet cause when I get a fairing lined up (which I planned from the beginning) I want the edge of the light to stick out as far or farther than the edge of the fairing. Does that make sense?
makes sense to me, any chance of a link to a bullet style light? The ones i am finding all seem to be mini or aftermarket ones that will not work with the frenched style trim rings that you can get from the MOCO. If you had a year or model range that the bullet lights were on that would be be awesome.
Thanks
Thanks
