Just installed Stage 1 SE Air Cleaner... Wow
When I purchased my 2011 Dyna Super Glide I had Screaming Eagle slip-ons put on at the dealer. Since then I added Xied's to correct the lean condition and let it run cooler. Yesterday I finished the Stage 1 by adding the SE A/C and took it for a ride. The results are impressive. Not only is it faster and more responsive but it sounds throatier then before. I love the added performance and sound. The install was fairly straight forward. The only issue was the little clip they give you to hold the wire to the back-plate. It comes with double sided tape and it came of when I tried to put the wire into the clip so I used a zip-tie to attach it to the wire that goes to the throttle body.
LOL. Like rooti said your never finished but it runs really well and I am not inclined to spend more on a more sophisticated tune. Now if any issues like pinging or popping arise then I will have to.
