damn....i want white walls!!!!
Old 01-14-2012, 07:12 PM
green-n-mean's Avatar
green-n-mean
green-n-mean is offline
Default damn....i want white walls!!!!
Cant find white walls in my size for my low rider! This sucks! Theyd look soo sweet on my bike! Anyone know where i can get a 17" rear and a 19" front?!!
Old 01-14-2012, 07:14 PM
Robtarra39's Avatar
Robtarra39
Robtarra39 is offline
Avon makes the 19inch, as for the rear not sure
Old 01-14-2012, 07:24 PM
Reaper_ggy's Avatar
Reaper_ggy
Reaper_ggy is offline
Cant remember de company but someone does a white add on to the tire that you squeeze between the rim and the tire itself and by memory its not pricey.
Old 01-14-2012, 07:34 PM
Reaper_ggy's Avatar
Reaper_ggy
http://www.youtube.com/watch?v=xkcm3rh60p0
you can do like this guy ? ... just kidding.
Here found it. Moon eye port o walls
http://www.youtube.com/watch?v=lpwUP...eature=related
Old 01-15-2012, 01:25 AM
WS6 Formula's Avatar
WS6 Formula
WS6 Formula is offline
Originally Posted by WS6 Formula
(PRICE IS FOR EACH)
Prices start as low as 10.00 per wall!
A quantity of 2 would be needed for each tire. This makes replacements easy and as needed.
An affordable and simple alternative to full-priced white wall tires are these Port-O-Walls, also known as White-Ribbons or Whitewall Toppers. Made completely of durable soft rubber, this simple addition drastically changes the appearance of your ride. Easy to mount, no special skills or tools needed.
They are held in by place by air pressure from the tire and the bead of the rim. The inside edge of the Port-O-Wall is pressed on the lip of the rim causing it to lay on the tire.
Available in many sizes and widths.
Customize your ride today!
The following are for motorcycle
WW1408MCEA > 8" . . . ....... . $10.00 each
WW1410MCEA > 10" . . ....... . . 12.50 each
WW1412MCEA > 12" . . ....... . . 14.00 each
WW1413MCEA > 13" . . . ........ . 14.00 each
WW1416MCEA > 16" . . .......... . 14.00 each
WW1417MCEA > 17" . . . . ........ 15.00 each
WW1418MCEA > 18" x 2" . . . . . 15.00 each
WW1418SMCEA > 18" x 7/8" . . . 15.00 each
WW1419MCEA > 19" . . . ......... . 16.00 each
http://www.youtube.com/watch?v=jNit3...layer_embedded
Old 01-15-2012, 03:55 AM
LoveHate's Avatar
LoveHate
LoveHate is offline
The important question is whether these Port-O-Walls, can be put on alloy wheels with tubeless tires?
Old 01-15-2012, 04:50 AM
Fat-Bob-Brad's Avatar
Fat-Bob-Brad
Fat-Bob-Brad is offline
Old 01-15-2012, 05:29 AM
TGWN's Avatar
TGWN
TGWN is offline
White walls, Just something more to clean. I wouldn't put them on a Dyna. More of a bagger thing. IMO
Old 01-15-2012, 08:01 AM
Y2KFXDman's Avatar
Y2KFXDman
Y2KFXDman is offline
If you use Port-O-Walls on a motorcycle, you had better glue them down with rubber cement. If you do not, they'll start flapping at higher speeds - not as bad as a tank-slapper, but it will get your attention. (Paraphrasing my father who describes his experience with these in the '60s.)
Old 01-15-2012, 08:31 AM
SteveO-ll's Avatar
SteveO-ll
SteveO-ll is offline
I like white walls on Fat-Bobs
Quick Reply: damn....i want white walls!!!!
