Bike Backfires and Then Won't Idle?
I hadn't ridden for a month,yesterday was nice so I went for a ride. After the motor was warmed up I ran it hard through the gears and it backfired when I shifted to 3rd. No big deal but when I came to a stopped it wouldn't idle but would respond to the throttle ok. I turned it off,restarted and it was fine. I checked for codes(none) and it runs normally now,what happened? Note that I have stabil in the tank for what it's worth.
I have a 2011 Softail Duluxe. Lately, every now and then after riding the bike and stopping to fuel it or turn off engine then after restarting I get backfire, rough idling, nearly dying and some backfire. Normally, after shutting it off and restarting it the problem goes away. Even when I have the problem it runs okay at higher rpms and accelerating. It has only happened about 3-4 times. I only have 8700 miles on it. Does anyone have any ideas?
Bob
Bob
I have similar problem, idle stalls occasionally, every restart it idles fine. Trust me, I have tried everything and it still does it. The problem is completely gone after I flashed my ecm with Power vision, not even once.
Do a search 07 idel issue, TT-410 TSB
https://www.hdforums.com/forum/touri...le-issues.html
Lambda
24
05-22-2021 09:18 AM
tkenney2nd@yahoo.com
10-26-2016 03:32 PM
flushguy
04-16-2009 06:49 PM
