FXDX shock issues
FXDX shock issues
Ok so for Christmas i got progressive 412's for my 01 fxdx yeah i know everyone says OEM are the best ones blah blah but I want it lower so i got the 11'' shocks which will lower it 2 1/2 inches so i may have to cut my fender and such but I am perfectly fine with that. Now my problem is the shock bolt is not long enough, the top of my stock shock is about 1/2 narrower then my new shocks. Has anyone else ran into this? I'm just curious if i can buy stock shock bolts for a dyna and they are longer then mine maybe? Thanks
If you selling your stock shocks I'd like first dibs at em.
I believe you can use the stock Dyna top bolts for the shocks.You will also need to relocate the wires in the fender. I made a simple bracket that attaches to the fender bolts to route it along the side. You may also want to consider flipping the bolts around. Use an acorn or cap nut on the outside. The stock bolts will rub the tire. I lowered mine with 1.75" blocks for a little while, but it bottomed out a couple of times 2 up. I'm 275+lbs. Depending on the day, so it was too much. If I ever did lower again I would only use the progressive 970's or other performance shock. Anything else and you're going backwards.
http://www.chuckhawks.com/super_glide_sport.htm
Not to be confused with FXDC, or FXDB, models of today.
