Are Ricor Intimidators worth it?
At the risk of oversimplification, intiminators change shock valving to be stiffer but they also have a release mechanism that, in effect, sudden changes (bumps) are not restricted as much and absorbed but longer term changes (diving, rebound) is more controlled.
I am happy with mine, absorbs small bumps well (haven't had to replace a filling since installing them), reduces dive, reduces chatter. Some of this may be due to the change in fork oil. I had high expectation, so it was not an oh-wow reaction for me... but reactions are subjective and your mileage may vary.
Progressive springs changes the spring rate, softer when extended, firmer when compressed. They don't provide more shock control although changing the fork oil may.
From reading dozens of posts here, riders seem to be happier with intiminator performance than progressive springs and shock oil alone. Personally I have not used progressives, however.
I agree with SC-Longhair, not a lot of difference with the intiminators installed. I pulled them out and sold them, then added heavier springs. What HD forks are missing is a heavy enough spring rate and once you get that you need to add rebound damping to control that spring rate. The only way to add only rebound damping to the stock components is to enlarge the compression damping holes in the damping rods and then increase the oil viscosity. The mechanism here it that the thicker oil increases both compression and rebound damping but you are only after increased rebound so you enlarge the compression damping area to return the compression back to the stock level.
I am currently using the progressive drop-in lowering kit. Also wondering if installing the intiminators will make things better at the front. Anyone done it and has the experience to share? Thank you.
I just installed a week ago and. .no 'wow' factor.
I didn't cut the spacers the 5/8" everyone seems to, wondering if it would make that much of a difference. Current front sag is now 5/8". Stock springs, Amsoil 10w oil at the recommended factory levels.
I took it over a road that has continuous 'light' bumps and it did great there. .but any potholes or larger bumps, I definitely feel them. .so I'm wondering if people are exaggerating how the Intiminators handle larger, sharper bumps. Do they just lessen the degree to which they're transmitted, or do they completely soak them up so you don't even know you went over them if you didn't look?
I've been watching my front wheel since installing. If I hit the brakes, the forks compress a good bit right away.
At this point I want to leave them alone but if someone can offer some insight into changing spacer length or adding/removing oil and if it got them to that 'wow' factor whereas they didn't notice anything before. .maybe I'll give that a shot.
Brian
2010, dyna, fork, forks, forum, front, harley, hd, intimidator, intimidators, nitrous, oxide, ricor, softail, suspension
