2010 Street Bob to Wide Glide conversion
I have just got done looking for about three hours at as many posts as I can and I still have a few questions about this swap that I hope I can get help with.
1) If I use the following parts posted by Bosken; then I believe it works for up to 07, however 08 and later is a 25 mm axle, so I do not believe this will work on a 2010. Am I mistaken?
V-Twin Item Details
Item : 24-1202
TOP TREE
FITS 2006 -UP FXDWG; FITS 49 MM TUBE
Units per Pack: 1
List Price: $117.50
V-Twin Item Details
Item : 24-1217
LOWER TREE, 49 MM
FITS 2006-UP FXDWG
Units per Pack: 1
List Price: $157.00
Item : 44-0691
1" AXLE, FITS 49 MM FORK
FITS 2006-UP FXDWG
Units per Pack: 1
List Price: $66.50
2) All the parts that are listed here, upon further review, are listed as 06-07. Is this another problem for a 2010 or should the trees be the same from 06 to current and it is just that no one has updated years of applicability?
Thank you for all your help on this matter. I have seen multiple Dynas do the conversion, and only 1 2009 SB, however I am still reserved about the axle size.
V-Twin Item Details
Item : 24-1202
TOP TREE
Units per Pack: 1
List Price: $117.50
V-Twin Item Details
Item : 24-1217
LOWER TREE, 49 MM
FITS 2006-UP FXDWG
Units per Pack: 1
List Price: $157.00
Item : 44-0691
FITS 2006-UP FXDWG
Units per Pack: 1
List Price: $66.50
There is one detail missing, the left lower fork slider is different on wide glides. The brake caliper mounts on the lower slider position the brake caliper further inside the wheel. So you will need to change the left lower slider or use spacers. The right slider is the same but the left slider that you need is part 46619-06.
Check out this thread, fatbob trees and wide glide are the same width so changing to FB or WG trees require the same parts, there is some more detailed info on one way to space the brake. Member WS6 used spacers on the disk and caliper but you could just add spacers between the slider and caliper. You could just use washers from the hardware store.
https://www.hdforums.com/forum/dyna-...bob-trees.html
