Touring air shocks installed w/pictures
#32
Depends what kind of ride you are after and what kind of riding you want to do, I like to run mine higher because I've found that the ride (anytime) is not significantly worse than lower pressures and I'm always ready to ride a twisty road which is usually my preference. That's the beauty of having the shock pump, with its built in pressure gauge and ability to fine tune in 1 lb. increments if you have it with you it only takes a minute to stop and adjust for conditions.
#34
Guys, can anyone tell me how the distance from the center of the top hole to the center of the bottom hole when, not mounted on the motorcycle.
I mean these Profile® Low Touring Shocks /54635-09/.
I can not find a drawing with dimensions in internet. I have to ask here, because the nearest HD dealer is 400 miles from me.
Thanks in advance.
Thanks in advance.
#35
Pretty damn sure it's 12" The full length Electra-glide/Road King shocks are 12 3/4 to 13 depending on who's measuring.Unless you're going for more cornering clearance or less money get the "Profile" or Street-Glide shocks.They look better, can handle more pressure and are probably sprung a little stiffer to make up for less travel.Now if you don't care about looks and you just want to try air shocks you can usually find a set of used Electra Glide shocks for 80$ or less on Ebay.
#36
Thanks in advance.
Thanks in advance.
https://www.hdforums.com/forum/sport...nd-length.html
and the 54635-09s are 12" they are what i have
also check the classifieds on here every day, that's where i bought mine
#38
#39
